hey so my friend let me on his MXR phase 90 M101 pedal since it was broken. Initially the pedal would not turn on. So i found a shorted out Zener diode and replaced it. the diode broken upon taking it out so i couldn't tell what the rating on it was.
now the pedal turns on, but only at the end (furthest clockwise) of the potentiometer does the effect turn on. the zener diode i replaced it with was a 5.7V 0.5W. i read somewhere that you match the zener diodes to the FET that is used. for the FET in the attached schematic they recommend a 4.7V. could this be the problem?
any ideas or ways to troubleshoot would be appreciated.
thanks
thanks
