MUX
Discussion in 'Homework Help' started by Justine1, Jul 28, 2010.
  1. Justine1
    Jul 26, 2010
    Please tell me what will be the block diagram of a 16:1 MUX using two 8:1 MUX!!....:confused::confused:
  2. tom66
    May 9, 2009
    2,613
    214
    Is this homework?
    It is very simple.
    You cannot use two muxes however.
    You must use two 8:1 muxes and one 2:1 mux.
    The 8:1 muxes select channel 0-15 and produce two outputs.
    You then select the right mux using the 2:1 mux.
    If you must use 8:1 muxes then with the last mux only two channels are used and only one select bit is used.
    Actually there may be a way to use two 8:1 muxes, if they have a chip select. However, you will need to implement external logic to select the first or second mux.
  3. JDT
    Feb 12, 2009
    658
    85
    It can't be done using two 8-input multiplexers alone. Depending on the type of 8-input multiplexer, some other logic will also be needed.
    The circuit attached shows how two multiplexers with "3-state" outputs (that can be made open-circuit using an enable input) can be combined using an additional inverter.
    The output goes open-circuit when the /EN input is high.
