MUX realization of logic
Discussion in 'Homework Help' started by TwoPlusTwo, Dec 11, 2010.
  1. TwoPlusTwo
    Oct 14, 2010
    51
    I'm supposed to realize the logic of a truth table (attached) with a multiplexer.
    Using the method in my text book I developed the connections below. My MUX has 3 data selectors (D, C and B) and 8 data inputs (0-7).
    Input Connected to
    0 High
    1 A
    2 High
    3 A
    4 Low
    5 A
    6 not A
    7 High
    I went through the states and it seems to produce the same output as the truth table.
    But in the solution (attached), my teacher did it differently, in a way that doesn't make sense to me. Can someone explain?
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    You are using D, C, and B as the select lines to the mux and your teacher is using A, B, and C, with C as LSB. These will yield totally different logic on the front end, so your result may be completely correct as well.
    From the table, when ABC is 000 and D is 0 the output is 1. When ABC is 000 and D is 1 the output is 0. Therefore, you teacher put the first output as 'not D.'
    TwoPlusTwo likes this.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    I read recently a nice formula to calculate your MUX inputs.
    Let F(A,B,C,D) be your boolean function and ABC (from MSB to LSB) your select inputs.
    Ii=F(Ai,Bi,Ci,D), where Ai, Bi and Ci are the nescessary inputs to achieve the selection of the number i.
    i.e. on your truth table, input 000 is I0=F(0,0,0,D)=D'.
