Mux 8-1
Discussion in 'Homework Help' started by mhi, Sep 3, 2008.
  1. mhi
    Sep 3, 2008
    I got 2 issue here.
    Issue 1: Design an 8 : 1 multiplexer capable of implementing the logic function below:
    F(A, B, C, D) = {1, 2, 3, 5, 6}, using A B D as the select inputs.
    Issue 2:
    Use the JK FF and design a ripple counter capable of implementing the counting sequence as stated below.
    F (x) = {0, 1, 2, 3, 4} and it repeats itself.
  2. hgmjr
    Jan 28, 2005
    What progress have you been able to make so far on either of the two problems?
    If you will post your early efforts to solve the two problems, there is sure to be someone that can provide suggestions/hints/guidance on how to get past any sticking point you have encountered.
    Critical to the learning process is that each student make a genuine effort on their own to work/struggle through to a solution. The solution can then be evaluated by someone who has knowledge of the subject and thus can identify where the student has not yet grasped the key concept covered by the problem.
