Mutual Inductance - Mesh analysis
Discussion in 'Homework Help' started by ydgmms, Dec 4, 2007.
  1. ydgmms
    Oct 6, 2007
    10
    I'm desperately trying to figure out this problem with ZERO luck.
    I'm thinking its either my mesh equations or my calculating Vo after I obtain I2.
    Mesh1 I get: 1*J1 + j6*J1 + j2*J2 = 10 angle 0
    Mesh2 I get: j2*J1 + j4*J2 + 4*J2 - j3*J2 = 0
    In Matrix(scilab input format, cuz I dont know how to do a matrix here)
    a=[ 1+6j , 2j ; 2j , 4+j ]
    b=[10;0]
    So then, to calculate J1 and J2, I do
    c=a/det(a)
    c =
    0.2416534 - 0.0206677i 0.0794913 + 0.0063593i
    0.0794913 + 0.0063593i 0.0524642 - 0.1558029i
    d=c*b
    d =
    2.4165342 - 0.2066773i
    0.7949126 + 0.0635930i
    Now I'm stuck here, getting my J2 into Vo. I try V=IR, so
    d(2,1)*-3j =
    ans =
    0.1907790 - 2.3847377i
    Which is not Vo according to the book...
    Anyone? :(
  2. The Electrician
    Oct 9, 2007
    2,300
    335
    Your problem is that the calculation c=a/det(a) does not give the inverse of a. Doesn't Scilab have a function like c = Inv(a) or c = Inverse(a)?
  3. ydgmms
    Oct 6, 2007
    10
    The example problem I was trying to follow, had the coeffecient matrix over its determinate. ?
  4. The Electrician
    Oct 9, 2007
    2,300
    335
    If you will scan or photograph the page(s) from the example you're trying to follow and post them, I'll explain what they're doing.
    In the meantime, if you will substitute c = inverse(a), (or whatever the correct syntax in Scilab is) instead of c = a/det(a), you will get the correct answer.
  5. ydgmms
    Oct 6, 2007
    10
    You are absolutely correct sir. I tried it with the way I SHOULD have the entire time. and within a minute I had the correct answer. Pissed me off to no end, i spent 2 hours last nite and i dunno how long monday and sunday nites.
    i did c=a\b, then d=c(2,1)*-3j and got the proper Vo
    Code ( (Unknown Language)):
    1.
    2. -->a
    3.  a  =
    4.
    5.     1. + 6.i    2.i
    6.     2.i         4. + i
    7.
    8. -->b
    9.  b  =
    10.
    11.     10.
    12.     0.
    13.
    14. -->c=a\b
    15.  c  =
    16.
    17.     0.5246423 - 1.5580286i
    18.   - 0.7949126 - 0.0635930i
    19.
    20. -->c(2,1)*-3*%i
    21.  ans  =
    22.
    23.   - 0.1907790 + 2.3847377i
    24.
    25. -->
    26.
    And when I convert ans into a phasor, I get the proper Vo.
    Thanks.. I dunno what the example problem and I were doing. :D
  6. The Electrician
    Oct 9, 2007
    2,300
    335
    See the attachment for an explanation.
  7. ydgmms
    Oct 6, 2007
    10
    Huh..interesting. I've never tried to figure out the inverse of a matrix by hand. Thats what threw me off. Never been taught it, always just been told 'use a calculator or MATLAB(scilab for us poor college students)'. So I thought they were doing something different when they had the matrix over its determinate.
    I had noticed the sign change of the -j5 values. But thought it may be a misprint, as during the course we've seen a few in the book.
    Oh well. Thanks for the explanation. I think I'll stick to scilab and how I normally solve coeffecient matrices.
