Mutual Inductance analysis circuit
Discussion in 'Homework Help' started by full, Sep 13, 2014.
  1. full
    May 3, 2014
    225
    Hello everyone,
    Actually I not understand the Mutual Inductance analysis circuit, but I do one problem ....
    Please can you check my solution true or wrong,
    thanks,
    • IMG.pdf
      File size:
      649.9 KB
      91
    Mahmoud Naser Esmail likes this.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I don't see how the mutual inductance can be 1H when with perfect coupling it can't be greater than 0.3536H.
    M=k \sqrt{L_1L_2}
  3. full
    May 3, 2014
    225
    can you see this youtube
    but I not understand in this video how do mutual inductance analysis :(
    how I know the mutual inductance is positive or negative ?
    but I do my problem form this key:
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    I fail to see the the point of trying to solve a problem based on a false premise.
  5. full
    May 3, 2014
    225
    ok sir, I will do another problem
  6. full
    May 3, 2014
    225
    I do new problem , please check loops 1&2 :
    thanks,
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    You do have a problem with the dot convention.
    My approach is simply to say:
    Current flowing into a dot on a winding produces a positive mutually induced emf at the dot on mutually coupled windings.
    So for your first mesh equation:
     -800+200I_1+j480I_1+j360 (I_2-I_1)+j720 (I_1-I_2)-j360I_1=0
  8. full
    May 3, 2014
    225
    but I think in rule of thumb on dot convention ( flow into*flow out =>negative)
    what is meaning emf?
    thanks,
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    In reality you can adopt whatever convention you like as long as you are consistent with the application of the "rules".
    The meaning of emf - electro-motive force.
  10. full
    May 3, 2014
    225
    sir, first of all, what is the meaning of the "dot"? (Mutual Inductance )true?
    and how can be calculated? thanks for your nice support
  11. t_n_k
    Mar 6, 2009
    5,448
    783
    The dot indicates there is magnetic flux coupling between one or more inductors as represented in a schematic diagram.
    As shown in your schematics the mutual inductance between the various inductors is indicated by the arrow(s) with an annotated value in units of inductance. Sometimes only the coefficient of coupling is shown and one then apples the formula for mutual inductance to determine the actual value.
    The location of the dot indicates the mutually induced voltage (emf) polarity in an inductor for a given condition (voltage or current) in a another mutually coupled inductance.
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    My solution attached.
  13. JoeJester
    Apr 26, 2005
    3,400
    1,218
    Interesting. I tended to believe the dots represented phasing, so you can tell whether or not the mutual inductance is aiding or opposing.
  14. ericgibbs
    Jan 29, 2010
    2,590
    389
  15. full
    May 3, 2014
    225
    Thank you sir ,
  16. The Electrician
    Oct 9, 2007
    2,300
    335
    Shouldn't that be two or more inductors?
    I remember a post in a newsgroup from some years ago concerning the situation where 3 inductors were coupled. A Spice simulation complained that the various mutual inductances were not physically realizable. Somebody posted a reference from an IEEE journal article where it was explained that if the matrix of self and mutual inductances were formed, it had to be positive definite to be realizable.
    JoeJester and t_n_k like this.
  17. full
    May 3, 2014
    225
    I am do this problem 3 time same answer :
    where is wrong?
    thanks
  18. t_n_k
    Mar 6, 2009
    5,448
    783
    The problem is with mesh 1 equation. Specifically, the term -j2*I1 should be positive sign rather than negative.
    full likes this.
  19. full
    May 3, 2014
    225
    obs :confused:
    thanks sir
  20. full
    May 3, 2014
    225
    I am do this problem in ideal transformer :
    where is wrong?
    thanks
