Musical led lights
Discussion in 'General Electronics Chat' started by mefmcw, Nov 23, 2010.
  1. mefmcw
    Nov 23, 2010
    Hi everyone
    I am totally new at this so please bare with me.
    I will try to explain what i am trying to do.
    I would like to set up some kind of led light bar/string lets say 50 led's, 4 maybe 5 different colors to go with the beat of the music coming from right, left, centre and sub.
    And i do have the led's, here is what i purchased.....
    Technical Summary
    RoHS
    Package ø 5mm
    Packaging
    bulk
    Dimensions
    ø5mm
    Lead Spacing 2.54mm
    Op.Temperature -40 ~ 85°C
    Color
    Set - R,G,B,Y,W
    Brightness 6000 ~ 12000mcd
    Wavelength 460 - 630nm
    Lens
    Waterclear, White
    Viewing Angle
    20 ~ 25°
    Forward Voltage
    1.9 ~ 3.5V
    Current Rating 20mA
    My audio system is a Sony STR-DG810
    6.1 Channel Audio/Video Receiver
    110 Watts X 6 Amplifier Power (8 ohms, 1Khz, 1.0%
    THD)
    Accepts up to 8ch Linear PCM through HDMI™
    technology
    HDMI Active Intelligence:3 Inputs/1 output(Video
    and Audio)
    Accepts 1080/60p signal through HDMI™
    technology
    BRAVIA® Theatre Sync™ technology
    DIGITAL MEDIA PORT
    Optimized for Blu-ray Disc™ and other HD Sources2
    XM® Connect and Play™ Ready with Neural
    Surround
    Portable Audio Enhancer with Front A/V Inputs
    Now my problem is what resisters do i need.
    And do i need anything else to make this work.
    Awaiting patiently
    Thax All
  2. retched
    Dec 5, 2009
    5,201
    313
    What you want is called a color organ. Use that as a search term here or in google and you will see many good designs.
    If you need search google for color organ circuit.
    There are standard VU bar integrated circuits that will handle the animation part. If it hears a loud sound, it lights more leds.
    Get searching. When you find a design you want to impliment, post a link here and we can help you adapt it to your leds and component system.
    mefmcw likes this.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    You bought cheap C****SE LEDs with a very narrow beam angle so they are nearly useless. Wide angle American or British LEDs should be used.
    mefmcw likes this.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
