Music chip?
Discussion in 'The Projects Forum' started by ecjohnny, Dec 3, 2011.
  1. ecjohnny
    Thread Starter Senior Member
    Jul 16, 2005
    142
    Hi guys.. i am wondering is there any IC chip or method/ways i can store just a single .wav or any other format of melody type to a chip. Because i am thinking of a project and i want to incorporate a music effect into my circuit which is only a single music/melody. i found some method that uses SD card etc.. it works but those flash memory size are big and exp which doesn't suit my needs.i think what i want is those circuit used in music greeting cards which i doubt are expensive and they play only single music/melody(looped)
    I am new to circuit so veteran out there pls help me.
  2. iONic
    Nov 16, 2007
    1,422
    68
    Browse the link below and see if anything meets your needs. There are some kits that you can build and would come with all the parts needed. Otherwise you will have to explain your needs as far as the size/space constraints, voltage source, and it's application (will it be used in conjunction with another device...) Do you need a specific melody??
    Voice Message IC
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Have a look at digikey.com.
    Type in the search field: "Voice". Then click on "Interface - Voice Record and Playback"
    You will find several options, one of the cheapest ($5) is THIS:
    Have a look at findchips.com to find out if the IC you choose is available for less at a different distributor.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    If you are looking for cheap (~$3.50), and simple, but very versatile...PICAXE 08M2 8-pin microcontrollers have a built-in programmable, tune function and a library of programmable tunes you can download. Free programming editor, and only needs a serial cable to program.
    http://www.picaxe.com/
    Ken
