Multithreading python,tkinter; basic start
Vindhyachal Takniki
Joined Nov 3, 2014
594
I have made a python code & using multithreading in it. this is very basic code, not using queues & other stuff.
Code has three files:main,analog,screen. Files are attached.
1. Main code just make three threads.
2. analog.py has two analog sensor connected. (right now I have only connected randint to generate values, otehrwise analog sensor will be connected).
one sensor update every 1 sec & other every 10 seconds.
3. screen.py has tkinter function. It keeps on self updating every 100msec. Whenever valid value comes in analog sensor it prints.
Check update_reading function in App class.
4. I want to know if its correct way to do, at very basic level.
Code is working fine, I have checked.
5. I will connect other sensor also, whose values will update in every 500msec or 2 sec & so on.
6. One additional query: update_reading function in App class, calls every 100msec. What if this function takes itself more than 100msec. What will happen then?
