Multisim
Discussion in 'General Electronics Chat' started by garyp, Feb 17, 2006.
  1. garyp
    Feb 17, 2006
    14
    Hi all
    I am using multisim 8 and i am trying to simulate a power supply. when i check the electrical rules (ERC) it says a number of wires are not connected even though they are. is there a fix for this.
  2. khanh
    Member
    Jan 6, 2006
    28
    Can you post your circuit?
  3. garyp
    Feb 17, 2006
    14
    here is part of the cicuit with the unconnected pins circled
  4. khanh
    Member
    Jan 6, 2006
    28
    Not sure where your error is ? but is your circuit still able to be simulated by click on run/stop simulation button??
    I notice that one I click and check all the options in the ERC button, it produces the exact errors like you have but my circuit is still running ? probly you should uncheck all this options.
  5. khanh
    Member
    Jan 6, 2006
    28
    I mean the "flow though" options, but not the other. My multisim is off by default in those options.
  6. garyp
    Feb 17, 2006
    14
    the simulation runs at first then i get the error stating that some components are not connected.
  7. khanh
    Member
    Jan 6, 2006
    28
    I never counter this error before. so why you don't post your circuit in multisim 8 extension (ms8), it may be the software that makes it failing in running. I can try and see if it happens to my system or not. better to have a full circuit around to try than having guesses and fail.
  8. Ron H
    Apr 14, 2005
    7,050
    655
    I don't use Multisim, but your schematic shows that some of the components are off grid (e.g., U1). Wires won't connect if this is the case. I suspect you placed some components while grid snap (or whatever they call it) was turned off. Check your options, if you have any. Also, see if it has an edit function like "force to grid".
  9. khanh
    Member
    Jan 6, 2006
    28
    Gary, your circuit you sent me runs very smooth with no error??????????????
    I wonder you've configure your multisim wrong but not sure where it is.Maybe you need to reinstall it to restore to default operation.
  10. garyp
    Feb 17, 2006
    14
    really i will try and reinstall it and see if it works. thanks anyway.
