Multisim - Vth
Discussion in 'General Electronics Chat' started by xxxyyy, Jan 25, 2012.
  1. xxxyyy
    Oct 7, 2011
    34
    Is it possible to find Vth (Thevenin's voltage) using Multisim?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Yes, if you build the circuit and simulate it.
  3. xxxyyy
    Oct 7, 2011
    34
    Here is original circuit:
    Code ( (Unknown Language)):
    1. http://imageshack.us/f/39/123456pj.png/
    My job is to determine the voltage seen by R5. I removed that resistor and connected Voltmeter instead of it, picture bellow.
    1. http://imageshack.us/f/812/7890.png/
    Is it correct?
  4. xxxyyy
    Oct 7, 2011
    34
    By the way, I calculated by hand that Vth should be 2V, but Multisim says that it is 4V, as you can see.
  5. crutschow
    Mar 14, 2008
    13,501
    3,375
    Is R6 the load or part of the Thevenin circuit?
    If its the load then you remove it and measure the voltage as you've shown.
    If its part of the circuit then you leave it in and measure the voltage across it.
  6. xxxyyy
    Oct 7, 2011
    34
    I made mistake in my second post, I said "My job is to determine the voltage seen by R6" and I later corrected it to "My job is to determine the voltage seen by R5". R5 is load.
