[Multisim] Transient time point calculation did not converge
Discussion in 'General Electronics Chat' started by xxxyyyba, Sep 26, 2015.
  1. xxxyyyba
    Aug 7, 2012
    249
    Hi. I have problem simulating this circuit in Multisim:
    (LTSpice)
    Here is scheme from Multisim:
    When I run transient analysis, I got this:
    ------ Checking SPICE netlist for Design3 - Saturday, September 26, 2015, 10:58:03 AM ------
    ======= SPICE Netlist check completed, 0 error(s), 0 warning(s) =======
    Simulation canceled
    Any idea what's wrong? Thanks in advance
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Do you need to connect the unused pins of the IC to something?
  3. xxxyyyba
    Aug 7, 2012
    249
    I don't think I need...
  4. xxxyyyba
    Aug 7, 2012
    249
    I tried different models of opamp and I got same error. Here is my version of software:
  5. xxxyyyba
    Aug 7, 2012
    249
    And with previous version I didn't have problems simulating circuits with opamps. I think this problem has something with opamp power supplies, if I remove them, simulation starts without error. But opamp must have power supply to work :)
  6. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Maybe your new software version is more picky about unconnected pins? Wouldn't hurt to add the offset null pot and compensation cap as per the datasheet. Convergence problems often need only a trivial adjustment of a circuit parameter to overcome them.
    xxxyyyba likes this.
  7. xxxyyyba
    Aug 7, 2012
    249
    Thanks for suggestions, I will firstly install older version in virtual OS to see if I can simulate same circuit.
  8. xxxyyyba
    Aug 7, 2012
    249
    I get same error on Multisim 13.0.1 Power Pro. There is something wrong with this model of op amp in both versions of Multisim I tried. :confused:
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    Can you upload Multisim 13 simulation file?
  10. xxxyyyba
    Aug 7, 2012
    249
  11. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Usually convergence issues are caused by shorts (I think?). Try adding small resistors (1 milliohm) in series with the power supplies. If I remember right, Multisim does not like "backwards" power supplies (used for the negative voltage supply).
  12. Jony130
    Feb 17, 2009
    3,990
    1,115
    LOL You connect your op amp power supply backwards. Pin 4 is V- and pin 7 is V+
    DerStrom8 and xxxyyyba like this.
  13. xxxyyyba
    Aug 7, 2012
    249
    @DerStrom8,
    I added 1 miliohm resistors in series with opamp power supplies and simulation starts without error. However, output voltage waveform doesn't look as it should. But I think we are close to solution :)
  14. xxxyyyba
    Aug 7, 2012
    249
    @Jony130,
    I made really stupid mistake :)
    Thanks a lot!
  15. Jony130
    Feb 17, 2009
    3,990
    1,115
    But why you simply do not use a LTspice? I think that LTspice is the best software for analog circuit simulation.
  16. xxxyyyba
    Aug 7, 2012
    249
    Well I'm not familiar with LTSpice yet but I definitely need to start using it.
