multisim problem, rlc circuit not analysing
Discussion in 'Homework Help' started by ninjaman, Apr 3, 2016.
  1. ninjaman
    May 18, 2013
    I am having a problem analyzing a circuits on multisim, a parallel rlc circuit. I have run the circuit with the probes to see the current through each component and I am getting the calculated currents. I then wanted to have a look at the real/imaginary and magnitude/phase results. I set this up and tried to analyse it and the software said "doAnalysis : matrix singular"
    I then tried to analyse it using AC analysis instead of single frequency and it came back with the same problem. I tried putting a resistor in series with the circuit with a very low resistance(0.000001) and it started to analyse but with no current or voltage or phase difference.
    not to sure what I am doing wrong here.
    any help/advice would be great!!!
