Multisim - capacitor collapsed
Discussion in 'Homework Help' started by user123456, Mar 31, 2014.
  1. user123456
    Jan 26, 2014
    12
    I'm suppose to take the readings from the multimeter for current but the capacitor is not working. What's the cause of this?
    One more question is there way to figure out the phase angel from multisim?
  2. shteii01
    Feb 19, 2010
    3,516
    515
    I think I am missing the symbol for capacitor.
    I think the easiest way to get phase angle is to use plots. The plot tool has traces? You can place the traces at the points, this will give you to values of time, use these values to calculate time delay, then use time delay to calculate phase angle. Here is the explanation: http://www.sengpielaudio.com/calculator-timedelayphase.htm
  3. crutschow
    Mar 14, 2008
    13,518
    3,386
    The symbol for your capacitor does not look like a capacitor. Actually I don't really see a symbol, just a short red line parallel to the wire connection. :confused:
    You can calculate the phase angle from the Power Factor reading in the Wattmeter. Alternately you can use the oscilloscope to view the current (using the current to voltage souce) and voltage waveform and measure phase-shift from that.
  4. user123456
    Jan 26, 2014
    12
    Yeah because my capacitor collapsed as soon as i ran the simulator, it changed the symbol.
    Sorry i should have provided a better description.
    Thank you, now i can figure out the phase angle.
  5. BytetoEat
    Mar 5, 2014
    25
    5
    lol.. i find it funny that multisim will collapse a capacitor!
