Multisim assistance
Discussion in 'Homework Help' started by shapes, Feb 22, 2005.
  1. shapes
    Feb 21, 2005
    i cant seem to get my TRIAC circuit in Multisim to operate
    it seems as tho it is not even triggering even when i connect a direct supply to the Gate
    can anyone c wat i am doin wrong in the attached drawing
  2. mozikluv
    Jan 22, 2004
    1,437
    hi
    base on the datasheet of your triac what's the gate trigger current. with your circuit you have about 17v supply and a current limiter resistor of 220ohms w/c will give you about 77ma of gate current. that current is way beyond the capability of your triac. the gate voltage for those kind of triac is usually 0.8v.
    in a real circuit you have already busted your device. :(
    have you not check the datasheet of the device you are using? even if you use simulations you still have to use the specs of the device :)
