Multisim 8 - dual power supply
Discussion in 'Electronics Resources' started by jarrah7rally, Mar 15, 2008.
  1. jarrah7rally
    Mar 15, 2008
    G'day folks,
    I am using multisim (ver 8 ?) to create circuits (for testing purposes) prior to real component construction.
    Normally I would use a dual power supply however multisim doesn't appear have this option - sure it has DC & AC along with CRO etc which is great
    Any ideas where it may be if indeed its available.
    Thanks in advance
    Cheers
    jarrah7
  2. scubasteve_911
    Dec 27, 2007
    1,202
    You just type in the value as being negative. So, when you place a standard 5V source, you simply type in "-5V" and it will be a negative voltage source.
    Steve
  3. mubarak azeez
    May 19, 2013
    Pls can someone guide me through. Am trying to build AC to DC circuit using multism ver.8 but i don't known the exact transformer to use. And i need 230 or 240 volt AC input to 35volts DC output.
  4. t06afre
    May 11, 2009
    5,939
    1,222
