Multiplixing 7-segments using MUC
Discussion in 'The Projects Forum' started by Musab, May 19, 2010.
  1. Musab
    Sep 20, 2008
    25
    I have come a cross the attached counter circuit while I was searching for my stopwatch timer project. the same principle of time-multiplexing is used in this circuit and mine. I would like to know the purpose of the 4.7kΩ resistors that are connected to the base of the transistors, are they for some protection purposes, or is it related to the transistors ? also, how was the resistor value calculated ?
    The transistors are used as switches.
    Thanks in advance,
  2. John P
    Oct 14, 2008
    1,636
    225
    That's an easy one. A transistor emitter-base junction is just a diode, and theoretically any voltage greater than ~0.6v will push unlimited current through it. The base resistors limit the current to about 1mA.
    The resistors were probably sized with a guess at the gain of the transistors, say 50 or so. Thus the current through the LED segments would be 50mA max--and I wonder if it's enough! That has to drive all segments of one digit at once; the per-segment current would be limited by R4-R10.
    By the way, the pic16f628a is pin-compatible with the pic16f84a, but it has more features and it's cheaper.
    Musab likes this.
  3. Musab
    Sep 20, 2008
    25
    Thanks John for the response.
    > Is there a formula to calculate the resistor value ?
    > I will have a look at the pic16g628, thanks for the advice
  4. Markd77
    Sep 7, 2009
    2,803
    594
    Normally as a rough rule of thumb I'd go for 1/10th the current that the transistor would be powering. Obviously you wouldn't want to go over the current capability of the PIC pin. 500 ohms would give you about 10mA which should be good.
    More saves power but means the transistor might get hot because it is only partly switched on.
    Musab likes this.
  5. Musab
    Sep 20, 2008
    25
    I found this formula in another website: Max base Resistance = (Vdd - 0.65) / (Ic/hFE)
    but I am not sure if it is the correct one. can anyone approve ?
  6. BMorse
    Sep 26, 2009
    2,675
    234
    Musab likes this.
  7. Musab
    Sep 20, 2008
    25
    Thank you guys, but I still don't get it.
    Isn't there an accurate way of measuring the resistance required, or at least the range of resistance values that can be used ?
  8. retched
    Dec 5, 2009
    5,201
    313
    You can look at the data sheet and see what the current limits are.
    You know the voltage you are working at, so ohms lay will tell you how much resistance you need.
    If you are using 5v and you have a IC that can handle a max or 20mA on any input pin,
    using ohms law:
    5v * .02 = 100 ohms
    So you need to have at least 100 ohms in resistance "protecting" that pin
    Some devices, like a 555, use the resistance between 2 pins to "tell" the chip something
    For instance if a timer counts 1second per ohm, you would use 60 ohms to "tell" the timer to count for 60 seconds.
    There is also impedance matching. Where a device may need a certain amount of resistance on the input or output for accuracy.
    The truth is in the datasheets.
    Musab likes this.
