Look at the two code blocks in #76 under EDIT2. I changed the way Int2Segs works for the DP so that we have control over flashing the DP in the time field. This second version takes a third parameter which is a mask to add a DP to any of the 3 digit fields. The too many actual parameters error is because your Int2Segs is the old (2 param) version but you are calling it like the newer (3 param) version.
Who says there ain't any simple answers?
