Multiplexers
Discussion in 'General Electronics Chat' started by Siyom, Oct 12, 2012.
  1. Siyom
    Aug 9, 2012
    33
    Which multiplexers can i use to switch between two voltages,5 and -9V.I've tried using an analog switch but am supplying it with 5 volts so it cannot switch higher voltages.
    I've tried scaling down the voltages but i cannot get the switch to switch negative voltages.
    Any help with this regard will be highly appreciated
  2. Ron H
    Apr 14, 2005
    7,050
    657
    We might be able to help if you tell us why you want to do this.
  3. Siyom
    Aug 9, 2012
    33
    Am using them as reference voltages for an A/DC
  4. Ron H
    Apr 14, 2005
    7,050
    657
    What is the part number of your ADC?
  5. crutschow
    Mar 14, 2008
    13,496
    3,373
    Why not use the -9V to power the negative voltage on the mux (CMOS muxes take only microamps of operating current). That would allow you to switch both the +5V and -9V. For example you can power the CD4051/52/53 with Vdd= +5V, Vss = 0V, and Vee= -9V, and then the mux will switch +5V to -9V with a 0-5V logic signal.
    What type of ADC takes a negative reference voltage?
  6. Siyom
    Aug 9, 2012
    33
    Dual slope integrating ADC
