Multiplexer
Discussion in 'General Electronics Chat' started by KCHARROIS, Feb 22, 2014.
  1. KCHARROIS
    Jun 29, 2012
    292
    I have a concern with using a multiplexer. I want to build an EMG circuit with 4 pairs of electrodes but only want to use one differential amplifier there for, I want to use a multiplexer to switch from each pair of electrodes before going to the differential amplifier. Should I be concerned of the very small input voltage going in the multiplexer and then out?
  2. crutschow
    Mar 14, 2008
    13,481
    3,368
    Normally no. A CMOS multiplexer looks like a small resistor in series with the signal when it is on. It adds no voltage of its own. But you should be concerned by noise pickup so you likely want all the circuitry shielded in a grounded metal box.
    KCHARROIS likes this.
