Multiplexer
Discussion in 'Homework Help' started by braddy, Sep 5, 2008.
  1. braddy
    Dec 29, 2004
    83
    How to build a AND gate using a 2X1(2 inputs, 1 select,1 output) multiplexer?
    The same for a NOT gate?
    I am stuck on it!
    thank you
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Use the truth table for the gate. The multiplexer selection inputs are A and B, the output is C. Arrange the input to produce the correct level for C according to the select bits.
  3. braddy
    Dec 29, 2004
    83
    thankx I will try to work it out!
