I need to use a multiplexer to select various power lines. I searched online and found many but the datasheets confused me a bit.
There's called Ron and Ron flatness what exactly is the difference between the two? I need one with as little resistance as possible. Also something about the current output, I want to be able to pass from very little current (~nA) all the way to 2A. What sort of specification should I look for in the data sheet?
Thanks!
Thanks!
