multiple UART with one microcontroller.
Discussion in 'General Electronics Chat' started by HIREN DAVE, Oct 2, 2013.
  1. HIREN DAVE
    Jul 18, 2013
    9
    I want to connect 8 GSM modems with 1 microcontroller. but my microcontroller has only one UART. So i need multiple UART. which are the techniques? is there any direct IC available?
  2. bance
    Member
    Aug 11, 2012
    315
    34
    Here is a good introduction to UART
    HTH Steve.
  3. ErnieM
    Apr 24, 2011
    7,433
    1,623
    There are code examples out there to create a "soft" UART on any I/O pin just using code. AFAIK a GPS is uses a fairly low data rate so you may be able to read 8 and still get useful work done.
    It may be better if you switch each on and off to a single UART and read each in sequence.
  4. MaxHeadRoom
    Jul 18, 2013
    10,816
    2,493
    Is your micro going to be the master?
    If so you could use a data switcher, starting with something like a MAX4948?
    Max,
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Or a "1 of 8" multiplexer IC?
  6. Jibby
    Sep 12, 2013
    15
    Use multiplexing IC to connect 8 GSM modems .
