Hi. I am working on a project and planning to replace the amplifier in a portable boombox radio to a higher powered one. The existing transformer can't be used because it was originally a european import (240v) and with our USA 120v mains, only outputs about 1/2 the necessary voltage. So I do have a bunch of NOS transformers in my spare part bin but they are smaller than I'd like to use for this application (12.6v @2.5a). The new amplifier is based on the TA8210AH chip. I think 2.5a will be insufficient to provide good performance.
I would prefer not to buy a new 5+amp transformer (1) to save money (2) because I have some transformers here available to use and (3) larger transformer might concentrate too much weight and stress at that corner of the portable radio.
So... asking if it's OK to install 2 of my 12.6v @2.5a transformers and run the secondaries in parallel to increase the available output current.
