"Multiple Solar Panels in Parallel"
Do you think that if you arrange your solar panels in parallel that it would be easier, even on cloudy days to hit your target voltage..?
I mean, what if you had 5,000,000,000 or even 3 solar panels that were rated at 1.0vdc, and you put them outside, arranged in parallel. Would more solar panels all working in parallel, even on a cloudy day give you better chances to hit your target (1.0vdc) voltage?
I don't care about the current (amps), only the voltage.
I'm well aware that the voltage (Vdc) stays the same, but multiplying the current (A & mA) and power (W Watts).
