multiple phase sine generator
Discussion in 'Homework Help' started by traitorousdevil, May 24, 2010.
  1. traitorousdevil
    May 24, 2010
    15
    Well... What should I do to the circuit to make sure the output voltage will be in the range of 0V to 20V.... And also, where do I add any indicator to show the failure of respective phases in case there is any
    short circuit occurs in any of the phases? Thanks for that... =)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You're talking about this circuit, I presume:
    As shown, the supply voltage is 6.5v. If you needed other output voltages, you would need to change the supply voltage.
    It won't produce true sine waves due to clipping. It's difficult to change the frequency. It is not a particularly wonderful circuit.
    The LM324 is an old and slow opamp. I used it simply because they are commonly available; even Radio Shack stores sell them.
    I suppose that an indication of operation could be implemented using three LEDs, current limiting resistors, and voltage followers to show that there are outputs from the three phases; they should all glow at about the same intensity. If there is a fault anywhere in the circuit, the feedback path would be eliminated, and it would stop oscillating - only one or two of the LEDs would be illuminated.
  4. traitorousdevil
    May 24, 2010
    15
    Thanks "beenthere"...
    Ermz... Rather than LM324, any suggestion for the ap-amp 2 produce 0-20v output from 230v input voltage with 50Hz frequency?
    Actually I totally don't have any ideas with the 3 phase sine wave generator... what the lecturer want from us is the "Single Phase to 3 Phase Stimulator"... And I found your circuit there seems quite suitable, so trying used with it... Without actually understanding... >.<
    So... Ermz... Could you please help to design a circuit...?
    Here the requirement...:
    1.The simulated 3-phase voltage supply has the wave shape, frequency and phase differences of an actual 3-phase voltage supply.
    2.0V to 20V user adjustable voltage amplitude.
    3.There should be indicators to show the failure of respective phases in case there is any short circuit occurs in any of the phases.
    4.Optimum load voltage regulation.
    Thanks..=)
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    So, this is a homework assignment.
    We cannot do your homework for you, as you would only learn how to get other people to do it for you.
    The circuit does have an element that you need, which is 120° between the output phases. However, your assignment is different, as the synchronizing input is from an existing source.
    You might start by investigating "ring oscillator" circuits, as that is what the circuit I posted is; a form of a ring oscillator.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    I suspected that this oscillator is dependent on the gain-bandwidth product (GBW) of the op amp, so I ran a sim. It appears that the frequency is proportional to the square root of the GBW, all other factors being equal. I don't have any inclination, right now anyway, to try to verify this mathematically.
    The voltage source on the 1st op amp helps get the oscillation started.
  7. traitorousdevil
    May 24, 2010
    15
    Guy... Please.... I totally have no idea with it... The leturer haven't taught us any about the oscillator yet... Asking us to design without teaching... What can i do without understanding... >.<
    Please.... >.<
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Google becomes a great research and learning tool. For instance, "ring oscillator" brings up 282,000 hits.
    If you encounter unfamiliar terms while reading about ring oscillators, use Google to get references for them.
  9. traitorousdevil
    May 24, 2010
    15
    Guys... I totally have no ideas... >.<
    Next week would be the date end...
    Any more hints please....
    Which Op-amp I should use?
    What I get right now just if according to #3's circuit,
    I am able to get the 120 degree phase shift...
    However, the op-amp there, LM324, does not suit to me as I have high input voltage and wish to generate higher output voltage too compare with the circuit...
    So, what I think here is, maybe I can replace other op-amp that can generate higher output voltage...
    The next problem is the frequency... In that circuit, what actually affect the frequency? I still can't get it...
    Well, in conclusion... Is that I'm trying use the circuit in #3 to transform into what I needed is a correct choice?
    Please... Give some hints... >.<
  10. Ron H
    Apr 14, 2005
    7,050
    657
    What voltage do you need? "Higher" is not very descriptive.
  11. Ron H
    Apr 14, 2005
    7,050
    657
    Here is a three phase (120° per phase) allpass sine wave oscillator that should have good frequency stability. With the values shown, the frequency should be 60Hz.
    This does not provide high voltage, as requested by the OP.
  12. JoeJester
    Apr 26, 2005
    3,393
    1,211
    To the OP ...
    Are you paying, or your parents are paying, for this education?
    If you are paying, then you are not getting your money's worth in this deal.
