multiple OS on the same computer
Discussion in 'Programmer's Corner' started by nemo1986, Mar 23, 2009.
  1. nemo1986
    Mar 4, 2009
    8
    I have Windows xp on my deskto and I want to download solaris to it. is is possible for both to run?
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    Depends on how the diak is partitioned.
    I have Vista and Suse linux on one PC.
    On my system the disk was in two partitions.
    I schrunk the second partition (it was a datapartition for vista).
    This can most times be done by the partitioning software of the linux installer.
    I mainly use the SUSE.
    Greetings,
    Bertus
  3. hearry
    Jan 18, 2009
    7
    I can say for linux with lilo loader that it will work, there is even no need to manually setup. what is needed to set your boot partition on linux one, where you instaled lilo(not on master boot). during lilo instalation you will get prompt for chosing your windows partition. On boot you will choose form win or linux.
    seting your boot partition is done for example with fdisk or similar tool.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    You can better use GRUB in stead of lilo.
    When a kernal update is done you have to poit to th enew kernel with lilo.
    GRUB does not have this problem.
    Greetings,
    Bertus
