Multiple LED voice volume bargraph
Discussion in 'The Projects Forum' started by Cyprobe, Mar 12, 2016.
  1. Cyprobe
    Mar 5, 2016
    7
    Hey there everyone!
    Been reading AAC website for a while, but recently decided to sign up and join the community :).
    Currently I'm trying to combine the non-inverting amplifier experiment:
    http://www.allaboutcircuits.com/textbook/experiments/chpt-6/noninverting-amplifier/
    with one of your users blog posts (Wendy):
    http://forum.allaboutcircuits.com/blog/leds-555s-pwm-flashers-and-light-chasers-index.378/
    in order to make an LED bargraph connected to a mic (electet). The volume of the voice input to the mic will determine the quantity of LEDs ON - the louder the sound, the more LEDs turned ON. (I guess it's possible to do it easier with just transistors, but i want to use an op-amp, for fun ;)).
    So i was tinkerring a bit and it worked, BUT as i plan to work with a 9V battery max, i can't go beyond 4 leds (voltage drop becomes bigger than Vsupply, as LEDS are in series, as I understand)...
    Do you guys think it's possible to redesign the bargraph so a 9V battery could turn ON, say, 10 LEDs and not in the same time?
    Thanks a lot in advance and hope I stated my problem clearly! :D
  2. shteii01
    Feb 19, 2010
    3,504
    512
    I did not look at schematic... but, you could add batteries. You can have two 9 V batteries in series, that would give you about 18 volts. Since you have 4 led now, with second battery you can have 8-9 led.
  3. Cyprobe
    Mar 5, 2016
    7
    Thanks for your reply.
    I understand what you mean, but actually I'd like to avoid to add additionnal batteries (if it's possible) and stick with a 9V.
  4. #12
    Nov 30, 2010
    16,703
    7,338
    Here's a completely different way.
  5. shteii01
    Feb 19, 2010
    3,504
    512
    ok, i am confused. says it can operate from single supply. what is pin 3 connected to? if i use 9v battery, would it go to positive terminal of the battery? also the led, the positive leg of led connected to the positive terminal of the battery too?
  6. #12
    Nov 30, 2010
    16,703
    7,338
    Pin 3 is clearly labeled V+
    So are the LEDs.
    V+ means, "The positive voltage source."
  7. shteii01
    Feb 19, 2010
    3,504
    512
    yes, and in the very first schematic in the beginning of the datasheet (page 1) is shows 12 to 20 volts there. i think i saw only one circuit in that datasheet that used 9v battery, everything else was 12 to 20 volt.
  8. #12
    Nov 30, 2010
    16,703
    7,338
    What is your question?
    Cyprobe and GopherT like this.
  9. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    Page 1 of the datasheet says the operating voltage range is 3 to 25 V. Of course, that entire voltage range does not apply to all possible application circuits.
    ak
    GopherT likes this.
  10. Cyprobe
    Mar 5, 2016
    7
    I'll try it. Thanks!
    I was still hoping for a chip-free 'primitive' circuit with a rewamped bargraph diagram, for practicing reasons, but hey ;).
  11. #12
    Nov 30, 2010
    16,703
    7,338
    Don't worry. This chip is at least 20 years old.:p
    And don't forget its brothers, a linear step display and a VU meter.
    LM3914, 3915, and 3916 if my brain is working today.
    (I can never be sure.:()
    Cyprobe likes this.
  12. dannyf
    Sep 13, 2015
    2,196
    417
    Tough to redesign it for you if you don't show what design you have in place now.
  13. AnalogKid
    Aug 1, 2013
    4,696
    1,297
    Most of the chip-free designs depend on the LEDs being stacked in series, which raises the operating voltage about 2 V per LED.
    ak
    Cyprobe likes this.
  14. Cyprobe
    Mar 5, 2016
    7
    Sure, you'll find an uploaded png image of the circuit diagram (which happens to work) in this reply.
    Edit: it's basically the two circuits which i linked in my first post, combined together (and + MIC).
    Ok then it is set :D.
  15. dannyf
    Sep 13, 2015
    2,196
    417
    Ok. The approach shown above have poor turn on ans turn off chartacters - meaning that the leds turn on and off gradually. Most people don't like that thus it is rarely used.
    A very simple approach would be to program a comparator like tl431 to set the on / off charteristics. One tl431 for each led.
    For smaller turn on or turn off points, use npn or n CH logic FET.
    Cyprobe likes this.
  16. Cyprobe
    Mar 5, 2016
    7
    Yeah I noticed that. Personally i don't mind but a non-gradual turn on would be better.
    Could you please specify why chose the tl431? Over any other op-amp?
    Edit: I glimpsed on a datasheet, and it seems to be a high-temperature voltage regulator.
  17. #12
    Nov 30, 2010
    16,703
    7,338
    The TL431 is a rather amazing chip. Originally billed as an adjustable zener diode, it can also be viewed as an open collector comparator with internal 2.5V reference. It's good to about 10KHz and can drain 150 ma. Look at the applications and realize how versatile this chip is.
