Afternoon all,
I am currently working on a project where I need to control various Leds and I could do with a bit of technical assistance.
The outline is as follow.
I will have 22 objects, that each has been embedded with two strands of fine 0.2mm coated coper wire. Onto this I have soldered 7x 0.25mm White Leadframe-Based Surface Mount Chip LED's in parallel. (This took some time, he he)
http://www.farnell.com/datasheets/80903.pdf
Due to the size and nature of this project there was no space for resistors before each led, so I hope that I can get away with it. Each unit or object embedded with 7 Led's works fine when connected to a 3v (2x1.5v) power source.
My main aim is to control or trigger each object so that all 7 leds should receive power at various intervals. Ie when all are placed together to form a random pattern consisting of 7 leds each.
To achieve this I am proposing to connect a switching transistor to the ground lead of each object, where each trigger pin on the transistor is connector to a output of a Arduino micro controller.
Thus in theory the Arduino can complete the switch for each object to close the power circuit, thus triggering the on/off of the leds. The leds will mainly be blinking at various intervals and won't stay permanently on for too long.
This is where I need some help to determine what transistor I should use and some advice on the general setup. Any assistance would be much appreciated!
I would like to use a transformer to power the setup as batteries might drain fairly soon under this constraint. I am fairly new to working with the Arduino, but I am sure that this basic stuff.
Thank you in advance!
