Multiple grounds in PCB
Discussion in 'General Electronics Chat' started by GVKR, Feb 18, 2013.
  1. GVKR
    Feb 16, 2013
    Hi !!
    am working with a circuit, in which i have to give two grounds separately for primary and secondary sides, and am working with PADS layout.
    so kindly help me...how can i create two separate grounds in PADS??And what are the factors that effect on ground??
    thank you in advance..:)
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The Completed Projects Forum is for Completed Projects only. It is meant to allow members to show plans for projects they built so other members can duplicate them if desired. New threads are also automatically moderated per Moderator review for this reason. Your thread does not belong in this forum, and was moved here.
  3. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Everything on a common net is connected in layout programs. If the grounds are truly separate you need to indicate that in the schematic so they are on different nets.
    If PADS doesn't have multiple ground symbols you need to make some.
