good day!
i am planning to create a multiple band pass op-amps, meaning i am allowing to pass different set of frequencies that desired, for example 3
frequencies from a remote transmitter let say 25khz, 30khz, and 40khz respectively. now i dont want to use MCU because it needed programming, i just
want to use 3 set of pass-band op-amps for the 3 desired frequencies, from a single receiver. its still a concept from me if this concept will work
using discrete components and not using mcu's. the actual application will be on controlling output stage with IR transmitter with
pre-determined frequencies. heres the block diagram
hope you can give ideas with this one
thanks in advance!
