multiple feedback bandpass filter
Discussion in 'The Projects Forum' started by BadBoy5537, Apr 28, 2009.
  1. BadBoy5537
    Apr 28, 2009
    I have to design a 4 band audio equalizer using a multiple feedback bandpass filter
    with given normal center frequencies (0.30kHz, 1.05 kHz, 3.7 kHz, 13 kHz)
    a quality factor of 0.9 and adjustable overall voltage gain between 0.2 and 2 for each band
    i used the equations f_o= 1/ (2*pi*C sqr R1*R2) and Q = 0.5 sqr R2/R1
    i got resistor values of 20k for R2 and 5.1k for R1
    my issue is when i plot the overall gain in pspice for each band set at 0.2 i get to high of a gain
    any suggestions thanks you in advance
  2. BadBoy5537
    Apr 28, 2009
  3. Darren Holdstock
    Feb 10, 2009
    262
    11
    You have gain peaking because a Q of 0.9 is underdamped (Q=0.5 is critically damped). Normally in the MFB BP circuit there's another resistor forming a potdown with R1 - I have lots of info on that, but sadly very little on the (perfectly cromulent) alternative circuit you've used here. Fortunately there's google - there should be some equations linking gain peaking magnitude to Q out there somewhere. This gain peaking magnitude equation is often a scaling factor for the separate equation for passband gain when the circuit is critically damped.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I could not help but notice that your filter is a departure from the classical multiple feedback bandpass filter topology. This may not be a significant obstacle but it could have an impact on your gain.
    I have attached a couple of png files that I harvested from the Internet to illustrate my point.
    What gain are you getting that you are calling too high?
    hgmjr
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    I think you need to put a resistor in series with each of the potentiometers. You really don't want to allow the series resistance go all the way to zero. If you use a 1K for example, you would be able to adjust the gain of the final stage from a high of -1 all the way down to -0.091.
    Are you getting a midband gain of -2 through your active filters?
    hgmjr
