multiple feedback band pass filter question pls help me, thanks in advance
Discussion in 'The Projects Forum' started by stupidmonkies, May 26, 2009.
  1. stupidmonkies
    Dec 10, 2008
    This is a circuit i get in a schematic. I search all over the internet and i get the result is this is similar to a multiple feedback bandpass filter but there is an additional capacitor between non-inverting input and inverting input and connect to ground. Theoretically when high frequency, capacitor have low impedance and so it will short this two input right? what will happen if we short it? If it's not to short the two input, what will it function as? I really scratching my head to figure it out but i just cant get it, hope someone can help me to figure it out, thanks in advance.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The 27pF value is very small compared with the main frequency determining components for the bandpass region. It won't have any influence on the designed pass band values. It's probably there to improve high frequency behavior or to minimize the likelihood of unstable circuit conditions arising.
  3. DickCappels
    Aug 21, 2008
    2,779
    674
    Yep. Besides that, its shunted by the feedback. Apparently, its only purpose is to reduce loop gain (and increase noise) at high frequencies.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Texas made a nice application notes on filters.(see attached PDF)
    Greetings,
    Bertus
  5. stupidmonkies
    Dec 10, 2008
    I see, now understand already, thanks a lot. But i have another question, what if i add another capacitor (with value of 1uF) before the resistor at Vin? It would apparently became an high pass multiple feedback circuit right? Then is the 27pF capacitor still function as the same? or it became a 3 pole filter? but as i knew, 3 pole filter using only one op-amp will give us unstable output that went into oscillation right?
