multiple 555 servo control question
Discussion in 'General Electronics Chat' started by jtrout13, Feb 19, 2011.
  1. jtrout13
    Feb 19, 2011
    Hi, I'm new to this site.
    I am building a robotics controller for part of a junior design project at university. I am studying mechanical engineering, and would appreciate any input to this question:
    Anyway, my robot has 4 servos. I am using potentiometers from a model airplane controller to adjust pulse width for speed and direction control of modified servos. Anyway, I plan to use one 555 timer in astable mode setting a clock frequency of 50hz, triggering monostable 555's which set the pulse width. I'm sure you are familiar with this type of application. On to the question:
    Will it be okay to use a single astable 555 to trigger all 4 monostables, or do I need to set up an astable/monostable combo using a 556 chip for each servo? To reduce parts count and space in the controller, i'd like to use a single astable 555 and combine the 4 monstables on a 558 IC. opinions will be greatly valued.
    Thanks!
  2. grahamit
    Dec 9, 2007
    I found a circuit for you that should work well. It's here.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    We have just had a very long thread in which the OP used that circuit:
    http://forum.allaboutcircuits.com/showthread.php?t=47149
    1) The 3M3 Ω resistor is too large.
    2) The pinouts to the servo are wrong for the vast majority of modern servos -- positive and negative are swapped. The center pin on modern servos is usually positive.
    3) That circuit is for manually controlling a servo. It is a little hard to see how that would have much use in a robot.
    John
  4. nomurphy
    Aug 8, 2005
    567
    12
    It seems to me that you should be able to use a single 555 output (not all things considered), you may need to buffer the 555 output for higher drive currrent or faster edges. But, also consider that a single 555 will provide some synchronicity, whereas multiple sources will be out of sync with each other (if that's important to your design or not).
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    At the point you need 4 circuits may be time to consider a microcontroller, especially at a junior level in a university.
