Multimeter Problem (UT136)
Discussion in 'General Electronics Chat' started by guruji, Nov 3, 2014.
  1. guruji
    Nov 11, 2005
    29
    Hi I have same problem like this guy. The Freq is not working only 0000 on my meter.
    My meter is UT136 model.
  2. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    Please start another thread cause look at the last time someone posted here beside you??
  3. wayneh
    Sep 9, 2010
    12,394
    3,246
    I was surprised to learn that isn't true. For instance, see these specs for a fuse I recently bought. At 210% of the rated value, it can take up to 30 minutes to open. That's referred to as a "fast acting" fuse.
    Gaaaa! Thanks Dr., I missed that.
  4. guruji
    Nov 11, 2005
    29
    Hi Dr killjoy why should I if this guy have same problem. If someone else see this thread will follow the whole story.
    Wayneh are you saying this guy was who started the thread was joking?! I said that I have same problem.
  5. wayneh
    Sep 9, 2010
    12,394
    3,246
    You should start your own, fresh thread. You'll get more feedback.
    You can link to this old one if you like.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  7. guruji
    Nov 11, 2005
    29
    Hyjack???!!!
    Don't know what you're talking about bertus anyway if you can help me with this multimeter problem I appreciate.
  8. wayneh
    Sep 9, 2010
    12,394
    3,246
    That's when you divert a thread away from the original poster's (OP's) concern. Although your topic is very similar, think of that old thread as belonging to that OP.
  9. crutschow
    Mar 14, 2008
    13,508
    3,384
    What voltage and frequency are you trying to measure?
  10. guruji
    Nov 11, 2005
    29
    I have a small circuit with a 555 timer on a 9v battery.
    On the manual of this multimeter I saw it somewhere that it's to 10vrms range. Don't know if this is saying above or below 10vrms for frequency measure.
