Can the diode test on a multimeter also work as a continuity test?
X Thread Starter x1222 Joined Oct 22, 2011 31 Nov 29, 2012 #1 Can the diode test on a multimeter also work as a continuity test?
spinnaker Joined Oct 29, 2009 7,830 Nov 29, 2012 #2 Of course. But most modern multimeter have an audio continuity tester making testing a lot easier.
M MKCheruvu Joined Nov 20, 2012 30 Nov 29, 2012 #3 Multimeter can indicte continuity but cannot represent diode data sheet charactristics.
crutschow Joined Mar 14, 2008 34,469 Nov 30, 2012 #4 The only difference between the diode test position and the normal resistance test is the output voltage. The diode test voltage is high enough to forward bias a diode whereas the normal resistance test is generally not.
