Multi testing
Discussion in 'General Electronics Chat' started by jismagic, May 12, 2014.
  1. jismagic
    Sep 7, 2013
    77
    I have to switch a load between 9 products to enable automation.
    I can think of putting 9 relays , each one to handle 10-20A. The relays to handle
    these high current are very costly.
    is there anything out of box i can apply to achieve this.
    thanks
    jis
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    you dont mention at what voltrage these relays will be used. if at 12 volts dc, automotive relays are quite reasonable priced.
  3. inwo
    Nov 7, 2013
    2,435
    315
    If you are in the USA the surplus market abounds with NEMA rated size one motor starters. 27A
    I just bought 8 Cuttler Hammer for $5 each on Ebay for a bridge crane refurbishing.
    The originals lasted 50+ years of PWM ( :D )service.
    Contacts were as new.
  4. inwo
    Nov 7, 2013
    2,435
    315
    Or these 40A definite purpose contactors, brand new for ~$10 as I recall.
  5. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    You might be able to find solid state relays at better prices than electro-mechanical ones - but there's a few gotchas if you need to switch reactive loads.
