multi serial?
Discussion in 'Computing and Networks' started by heavyarms666, May 25, 2009.
  1. heavyarms666
    May 16, 2009
    20
    h¡ everyone! Anyone here knows how to connect many(about 3-20) serial device in a single computer?
  2. steinar96
    Apr 18, 2009
    239
    I doubt that is possible unless you are programming the serial driver yourself and are willing to sacrifice 4-5 input lines to select which of these 3-20 devices you are using during each transmission. The recieving end of the serial line would also have to be programmed or designed to sense whether they're address is active on the select lines or not.
    At least i have not heard of multiple serial for a single computer unless you are using a switch, but i think those are pretty expensive at 20 inputs, and also you would have to switch between devices manually with those kind of switches.
  3. heavyarms666
    May 16, 2009
    20
    thanks! this is the what happen, my group present many good and quite easy proposal for a thesis like voice operated car.. but my stupid propesor make his own idea and gave it to my group.. the ida was to set-up rfid reader for every room in our university.. imagine! how many rooms we have, so we bargain it to atleast in 3-20 range.. it will cost a lot! so if we set-up atleast 3, our system must be ready for a 20 slot..
  4. AlexR
    Jan 16, 2008
    735
    54
    I don't know about 20 port but I know you can get 16 port serial cards for a PC.
    Do a google on "multi-serial card.
  5. AlexR
    Jan 16, 2008
    735
    54
