Here is one for you experts.
I'm looking at doing a 24VDC project that has one 24V source but requires 5 separate outputs. The first output would start at a pre-determined time of day. Each output would have a duration of approx. 1 min. (Should be adjustable). There would be a couple of hours interval (also adjustable) between the first output and the second output and so on. This cycle would repeat on a daily basis.
The outputs would be energizing individual relays that in turn would be switching power on and off to 24VDC motor (1.2A)
I'm assuming that there is no such timer readily available and that this would have to be built by assembling 5 individual timers on a board.
Any advice would be appreciated.
Thanks in advance
Thanks in advance
