Multi-frequency detection and conversion.
Discussion in 'The Projects Forum' started by Chygoz, Apr 27, 2011.
  1. Chygoz
    Apr 27, 2011
    14
    I'm working on a project which involves the fm detection of different frequencies and the conversion of these frequencies to voltage. Basically, i want the circuit to be able to detect a range of frequencies and produce a distinct voltage for each of the frequencies. The entire range of frequencies need not be present at the same time. Can anyone give me an idea and possibly a circuit diagram on how to achieve this? Any contribution is appreciated.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Lots of details are missing. Are these frequencies modulations of the FM carrier? What is that carrier frequency?
    A set of filters can do the frequency detection.
  3. Chygoz
    Apr 27, 2011
    14
    Yes these frequencies are modulations of the fm carrier. The carrier is 100MHz.
  4. CDRIVE
    Jul 1, 2008
    2,223
    99
    Why is it that most of the posts that fall into this topic arena seem to always be 100MHz, which falls into the commercial FM band?
    Anyway, what you're describing is called "PL" tones, meaning "private line". In the old days this was accomplished with resonant reed relays, which were eventually replaced by a PLL tone decoder which, in turn, was superseded by microcontrollers. Most of the commercial radios today use DPL which translates to "digital private line".
    How many tones do you want to decode? If you have more than a couple the PLL decoders will take up considerable real estate.
    Chygoz likes this.
  5. Chygoz
    Apr 27, 2011
    14
    Thanks for the info. I'm thinking of working with 3 different tones. As for the carrier frequency, i may change it to something else once i understand the circuit .
  6. CDRIVE
    Jul 1, 2008
    2,223
    99
  7. Chygoz
    Apr 27, 2011
    14
  8. CDRIVE
    Jul 1, 2008
    2,223
    99
    Bad or broken link.
  9. Chygoz
    Apr 27, 2011
    14
    Here's the circuit diagram.
  10. CDRIVE
    Jul 1, 2008
    2,223
    99
    Here's the data sheet.
  11. Chygoz
    Apr 27, 2011
    14
    Thanks for that. I've been trying to get it for a while now.
  12. Chygoz
    Apr 27, 2011
    14
    Thanks for that. I've been looking for it's datasheet for a while now.
  13. CDRIVE
    Jul 1, 2008
    2,223
    99
    Your welcome but it wasn't that hard to find.;)
  14. Chygoz
    Apr 27, 2011
    14
    The datasheet consists of two circuit diagrams: the test circuit and the application circuit. Which of them is to be used? Because none of them is similar to the circuit in the picture i uploaded earlier.
  15. CDRIVE
    Jul 1, 2008
    2,223
    99
    Fig(1) is a block diagram, while Fig(5) is a typical practical circuit.
    Where did you get the schematic that you posted?
  16. Audioguru
    Dec 20, 2007
    9,411
    896
    The Philips TEA5591 AM-FM radio IC had poor performance and is obsolete. It has not been made for many years and the newer TEA5711 also is obsolete and also has not been made for many years. Sony also used to have a few radio ICs.
    I don't know of an available simple half-decent radio IC. I have the datasheet for the TDA7513 that is used in modern car radios and it is surface-mount with 80 tiny pins.
  17. CDRIVE
    Jul 1, 2008
    2,223
    99
    I'm beginning to think that Chygoz would be better advised to search for kits. Even if he could obtain one of these chips the parts cost would be far greater than purchasing a board kit. The forum time, calculating all the components, would also break records for longest thread. ;)
  18. Chygoz
    Apr 27, 2011
    14
    Okay. Thank you all for your contributions. I guess i'll just have to work with a different circuit then.
  19. CDRIVE
    Jul 1, 2008
    2,223
    99
    Is this a class project or assignment?
  20. Chygoz
    Apr 27, 2011
    14
    It's a final year project.
