Multi emitter transistors
Sparky49
Joined Jul 16, 2011
833
Hi all,
Studying one of my bargain books, I come across an interesting (but brief) portion which mentions multi-emitter transistors.
A quick Google search reveals that they are used in logic designs, but what is their actual construction?
I presume that each emitter leg does not use the same bit of silicon, but wouldn't having multiple bits of p silicon, (or indeed n type) affect the operation of the overall transistor?
Many thanks,
Sparky
jwd217
Joined Jun 19, 2012
5
Multi-emitter transistiors are used extensively in 7400 series of digital integrated circuits. Each emitter would be a seperate bit of silicon. They function exactly like several diodes connected together in the correct polarity. The only difference is that the transistors could operate at a higher frequency than the diodes could. As digital integrated circuits it made 2 to 8 input nand gates possible.
chuckey
Joined Jun 4, 2007
75
The emitters do all go to the same base junction. The 2n3866 VHF medium power transistor ( circs 1966) had over 110 emitters which were all connected together to give a really low inductance lead from the die.
Frank
WBahn
Joined Mar 31, 2012
30,083
Frank
Are you sure these were separate emitters and not simply a multi-bonded node? If they were separate emitters, then you could apply different voltages to them without causing any problems.
