Do you only want to calculate capacitance? Then materials don't matter and...I've searched everywhere, but couldnt find any info on multi dielectric capacitors.
my question is how capacitance of parallel plates multi dielectric capacitor will be calculated??
But they do. The dielectric constant of the material between the plates affects the capacitance.Do you only want to calculate capacitance? Then materials don't matter and...................
Couldnt find anything related there
It matters as the capacitance is in relation with kappa (dielectric primitivity relative)Do you only want to calculate capacitance? Then materials don't matter and...
- Parallel capacitance is additive,
- Series capacitance is calculated just like PARALLEL RESISTANCE.
If you want to get into ESR, frequency response or other phenomena of capacitors, there is more to the story.
it really helped. thanks.Hello,
Have a look at the following PDF:
http://educypedia.karadimov.info/library/lecture13.pdf
Page 23 and on are about two dielectrics in a capacitor.
Bertus
Thread starter | Similar threads | Forum | Replies | Date |
Multi function Christmas lights | General Electronics Chat | 2 | ||
K | Multi bridge ISP sharing | Wireless & RF Design | 1 | |
B | Multi-Stage Amplifier Project | Homework Help | 69 | |
Open-source Multi-zone heating controller/wiring centre | Sensor Design & Implementation | 1 | ||
M | Interfacing single master with multi slave | Microcontrollers | 7 |
