Multi Charger for Tablets & Mobiles Powered by Solar Panel
Discussion in 'General Electronics Chat' started by gasman53, Nov 20, 2013.
  1. gasman53
    Nov 20, 2013
    I am new to this site and have nothing to do with electronics but am looking for some advice.
    I have installed an 80watt solar PV panel with a solar charge controller and have purchased an Orico DCS 118U-BK charging unit that will charge 2 tablets and 2 mobile phones simultaneously. The unit is powered by a 240v AC input to 12V DC 3A output power supply. I could use a 12v DC to 240v AC inverter to power the charging unit but would rather connect DC to DC.
    It seems the output voltage from the charge controller may reach 15V DC so my question is:- would the charging unit be likely to suffer damage due to the higher voltage? and if so is there a cheap way to provide a stable 12V DC (12.4V when I measured it with a meter) 3A output from a variable DC input?
    Your help would be gratefully received
    Regards
    Steve
  2. wayneh
    Sep 9, 2010
    12,374
    3,225
    Take a look on e-bay for DC-DC converters. You may find something that meets your needs.
