Mud Huts
Discussion in 'Off-Topic' started by thingmaker3, Jul 29, 2007.
  1. thingmaker3
    Thread Starter Retired Moderator
    May 16, 2005
    5,072
    6
    My wife and I just spent some time in a temperate rain-forest learning to build cob housing. The workshop was quite enjoyable, not only for skills learned, but also for camping out in an idyllic setting with such creative & motivated folk.
    "Cob" is a composite of clay, sand, and fiber, formed into a monolithic wall structure. The word originally meant "round," or a round blob of said composite.
    This material is astoundingly well suited to homes - I'm amazed that it is so "new" to North Americans. Earthquake resistance is far superior to most other building types. Thermal mass makes for excellent energy efficiency in heating and cooling. There are 2000 year old, ten story tall cob buildings in Yemen which still serve their occupants adequately. There are oodles and scads of millenium old cob houses across Europe.
    These things are inexpensive to build and take very little skill. I suspect we Americans have forgotten them simply because we've no way of making a profit from them.
    I'm curios: does anyone on this forum dwell in a cob or other earthen housing?
  2. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    No, although I have worked in a few. Total pig to renovate, ceilings get increadibly dusty, and nigh impossible to rewire.
    Another fad here is hay or straw bale houses. Also a cow to work on.
    Hebal (or airated concrete) is starting to become very popular however.
  3. GonzoEngineer
    Jul 8, 2007
    46
    Adobe! Houses all over the southwest that have survived for hundreds of years.;)
  4. thingmaker3
    May 16, 2005
    5,072
    6
    There was one building in the complex which had been re-wired. I could tell because they were unable to match plaster after firring out a channel for the new wire!
    Tell me, Gadget, do the New Zealanders use direct burial cable in the walls, or regular old NM type? Or is conduit layed?
    The folk teaching have been experimenting for five years with combining straw-bale and cob together. They use cob-lined straw bale walls in the North and West for maximum insulation, and cob-only walls in the south and east for maximum advantage of thermal mass. Bales in the hybrid walls are laid with the straw running vertically, and the bales are compressed horizontally by either cob pillars or plywood forms. Any gaps or voids are filled with cob, and the interior is covered with 75mm to 150mm of cob. Bale exteriors are covered directly with plaster.
    Adobe certainly is a good material in geologically stable areas! Here in the "Pacific Ring Of Fire," however, any brick building would be shaken to rubble in short order.
    Another technique shown during the workshop was to incorporate adobe-like bits into the wall interior to reduce wall drying time. Uneven surfaces on the bits, and dunking quickly in water just prior to incorporation, allow the bits to be fully integrated into the monolith composite.
  5. Gadget
    Jan 10, 2006
    613
    In these styles of building, normal 3 core 2.5mmTPS is run inside plastic conduit. Normal housing uses unprotected TPS inside the walls, and a special (Purple) TPS is required when running thru polystyrene due to reactions between normal white TPS and the poly. Would have to get any more detail from one of the other guys at work, as I am the resident Electronics tech, not one of the sparkies.
    Most houses here are Brick, or Wood and concrete foundations with wooden framing with appropriate bracing and trussed metal clad roofs. We are on the ring of fire here too, and everything seems to work OK. The last 7.1 (2 years back) put a crack thru my foundations, but apart from scaring me outside at 2 am, did no other real damage...(to housing anyway). Shelves were a different story.
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    My missus wants to live in one of those houses that Hobbit's live in! Does that count! :D:p
    Dave
  7. n9352527
    Oct 14, 2005
    1,198
    Make her dream come true :D
    http://www.simondale.net/house/
  8. thingmaker3
    May 16, 2005
    5,072
    6
    IIRC, a hobbit style home would be classed as "underground housing."
    I do have two designs for 7' (3.3m) dia doors, but my wife has yet to approve either...
  9. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Lol!! I love it! :D
    Wait till I show here that website later, we may have only recently moved house but I'm sure she will want to move again immediately!
    So we would be classified as vermin?!
    I would like to see the concluding designs for your doors - having spent a large portion of the last week replacing every door in my house I am now a quasi-expert!
    Dave
  10. mrmeval
    Jun 30, 2006
    833
    If a profit can be made from it Americans *will* do it. Cost and ease of construction, ease of maintenance, aesthetics ( esthetics?) and adherence to building codes are all factors.
    There are specialized builders who will make what you want within those constraints though it will cost you. They make lots of money catering to people wanting the unique, unusual, sustainable or bizarre.
  11. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  12. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Property is the new 'easy profit', which is a rolling bandwagon here in the UK too. The funny thing is, that some people think it is a fast way to make £5000 a week...interesting to see that the situation is no different elsewhere around the world.
    Dave
  13. n9352527
    Oct 14, 2005
    1,198
    You can have hobbit themed house warming party :D
    I have to confess I love that house as well. Such creativity and implementation! Probably not very practical, but who cares when living in a house like that :p
  14. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Good idea. No one above 4-foot is invited! :D
    Couldn't agree more, the whole project reminds me of Grand Designs on Channel 4. One thing I couldn't decipher is does the house have any form of electricity supply? Since it is an "eco-house" one suspects that it is not conneted to the traditional mains-supply, but I couldn't see if it had a biofuel generator - I wouldn't be surprised.
    Considering how cheap it was to make, I wonder in the current property climate, what is its market value.
    Dave
  15. n9352527
    Oct 14, 2005
    1,198
    It does say there are "solar panels for lighting, music and computing".
  16. recca02
    Apr 2, 2007
    1,211
    seems like LOTR in 2040.:D
  17. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Good stuff - I must have missed that part.
    Funny that, they have excessive magical powers but no electricity! :D
    Dave
