Mt3608 v/s mcp1640 Better Step Up Converter
Discussion in 'General Electronics Chat' started by sonar_abhi, Jun 20, 2016.
  1. sonar_abhi
    Mar 19, 2016
    16
    Hello Guys,
    I have been working on a boost converter to convert 3.7V to 5V supply. I have been using a MCP1640 for the same. But recently I came across a new chip from Aerosemi (maybe that is not new, but I came across it recently). It is MT3608. The datasheet is not that great and does not claim a tested product. The advantage of this chip is that it claims to be able to supply greater current (2A and the efficiency is 92%).
    Has anybody used it and if not can anybody please see the datasheet and check whether this would be a better product as a USB power supply than a MCP1640?
    https://www.olimex.com/Products/Brea...ces/MT3608.pdf
    Regards,
    Ace
  2. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    It's different, larger output voltage possible, larger minimum voltage, higher frequency.
    You couldn't use it to get 2.5v from single battery
