msp430 Infrared decoder
Discussion in 'The Projects Forum' started by orlysang, May 6, 2011.
  1. orlysang
    May 6, 2011
    I am trying to create an infrared decoder using a 38.5KHz receiver which output is the demodulated signal,this output goes into an msp430. I am sampling each 54us, storing each 1 and 0 (high or low voltage) into an array.
    To recreate the modulation i am doing 2 times a carrier frequency of about (36.5KHz) which is the one i am testing from a remote controller, this each time i see a 1 in the array. Is this a good aproach to sample and send back the same signal? is there another way to recreate an infrared signal ? Any advice would be of great help since the deadline for the project is n about 4 days and we are trying everything to make this work.
  2. Markd77
    Sep 7, 2009
    2,803
    594
    Another way is to store a time for each on/off transition. You might be able to get better resolution for the same memory requirement.
    orlysang likes this.
  3. orlysang
    May 6, 2011
    Just to end the thread my error was the sampling time, i was sampling for about 30ms and there are a lot of signals that the time duration is more than that.
