MQ-4 gas sensor
Discussion in 'The Projects Forum' started by ching fong kee, Jul 2, 2010.
  1. ching fong kee
    Jun 23, 2010
    42
    i wish to ask about the MQ-4 gas sensor
    how to differentiate it is left side or right side?[​IMG][​IMG]
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    So you have a datasheet?
    I'm betting the text is the trick, that or there is a notch somewhere you can't see in the picture.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. ching fong kee
    Jun 23, 2010
    42
    yes, i have a datasheet.
    but the datasheet does't show where is the front of the sensor.
    so i can't get where is the left side and where is the right side.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Look at the text, one side is up, the other side is down. This defines a left and a right.
  6. ching fong kee
    Jun 23, 2010
    42
    this is means, now im facing the side of sensor which have label MQ-4 there and i turn around will be plan digram in configuration B?
  7. retched
    Dec 5, 2009
    5,201
    313
