MPLABX is getting better
Discussion in 'Embedded Systems and Microcontrollers' started by Markd77, Feb 18, 2013.
  1. Markd77
    Thread Starter Senior Member
    Sep 7, 2009
    2,803
    594
    I've tried it again today on Linux and bits of it now seem to be working. I've managed to create a new project, done some simulation, and even programmed a PIC with it.
    To my mind it's still a beta version and it's really counterintuative, but another year or so and it might be pretty good.
    <rant>
    Before trying it I'd recommend reading the (massive) errata list, there could be a major bug with the PIC you want to use.
    There's still a lot to sort out, for example if you want to simulate you have to select the simulator as the debugger, then to program the chip you then have to change the debugger to your PICKIT, then back again for the next time you program the chip.
    If the chip fails to program MPLAB hangs.
    There are no settings that I could find to externally power the PIC. <ed> Found them now, thanks bance. </ed>
    </rant>
  2. spinnaker
    Oct 29, 2009
    5,076
    1,177
    What do you mean? Of course the pic can be externally powered. In fact it is the default.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Thanks, the software I've used before (PICKIT2 standalone programmer and PK2CMD) had the PICKIT powering the circuit by default and had a setting that would allow the PIC to be powered by another source.
    I'll give it a try at some point.
  4. bance
    Member
    Aug 11, 2012
    315
    34
    I agree, I use Arch and I've never used anything but MPLABX and it works just fine....
    The only problem I've had is with a 16F628, and that is probably because I programme to a breadboard using ICSP.
    If you double click your programmer, under project properties, it will bring up a dialogue allowing you to power your chip and tristate the pins so they can be used as I/O's...
    HTH Steve
  5. t06afre
    May 11, 2009
    5,939
    1,222
    I will still use and recommend the old MPLAB and not MPLABX. And I am also some puzzled by how small development steps take. Up to now MPLABX has just frustrated me
  6. Markd77
    Sep 7, 2009
    2,803
    594
    Brilliant, thanks. I thought I'd clicked on everything.
    This is the sort of thing I mean by counterintuitive, nothing in the menu, not in the other places I saw:
  7. ErnieM
    Apr 24, 2011
    7,437
    1,626
    As far as I am concerned MPLAB X is still a beta.
    Orly? This from a Microchip sample project after about a half an hour of trying to tie up the files it couldn't find.
  8. Markd77
    Sep 7, 2009
    2,803
    594
    The installation for me was one of the most straightforward that I have done on my new 64 bit Mint linux system. I had to run the install as administrator, but it prompted me to do it.
    A lot of software for 64 bit needs to be built from source code, but this was just a few clicks.
  9. bance
    Member
    Aug 11, 2012
    315
    34
    @ ErnieM
    You're clearly a WINDOZE user since you expect "free" software to work perfectly out of the box.....
    Us poor nixer's are used to software that doesn't.:D
