I am making some headway in writing simple programs, testing goto and decfsz, bit tests etc, just basic getting familiar with trying to write code. Using MPLAB I can set a bit high, low etc and test it and see if it works as it should, no problem there, I can simulate a high on a input in stimulus and I'm ok, my question is this, is there a place on MPLAB where I can set a bit on PORTA (a bit designated to be output) and see in the simulator somewhere the condition of that bit, like if it actually went high after the program set it, like an LED or something, I searched help and can't find anything, my device is a 16F84, thanks...jim
p.s. on the template...... w_temp EQU 0x0C (is 0x0C a hex address, is this a decimal 12)
