Mplab (project building error)
Discussion in 'Embedded Systems and Microcontrollers' started by ect_09, Jul 8, 2012.
  1. ect_09
    May 6, 2012
    180
    HI!
    MY CODE IS GIVEN BELOW.
    HERE IS THE PROBLEM WITH #INCLUDE <P18F452.INC>
    WHAT IS THIS PROBLEM.???
    Code ( (Unknown Language)):
    1.
    2. ////////////////////
    3.
    4. Processor 18f458
    5. #include <18f458.INC>
    6. org 00
    7. BCF     TRISB,5
    8.     MOVLW    0x08
    9.     MOVWF    T0CON
    10. HERE    MOVLW    0xFF
    11.     MOVWF    TMR0H
    12.     MOVLW    0xF2
    13.     MOVWF    TMR0L
    14.     BCF    INTCON, TMR0IF
    15.     BTG    PORTB,5
    16.     BSF     T0CON, TMR0ON
    17. AGAIN    BTFSS    INTCON, TMR0IF
    18.     BRA    AGAIN
    19.     BCF    T0CON, TMR0ON
    20.     BRA    HERE
    21. ////////////////////////////////////
    22.
    I ALSO ATTACH THE IMAGE OF ERROR PLEASE HELP ME.
    ACTUALLY AM NEW WITH MPLAB.
      File size:
      198.5 KB
      21
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    What compiler are you using? In the build window, it looks like you're trying to use C18, but you wrote the code in ASM. Also, try including the .h instead of '.inc'
    Or, another thought, try ".inc" rather than ".INC". I think it's case-sensitive.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Well metlab. It looks like the problem is that the inlude file 18f459.inc can not be found. Have you done a serch on your HD trying to locate it? If MPLAB is correct installed and you have made a project. MPLAB should have able to locate the correct inc file
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Good catch I think metlab have selected the wrong toolsuite then creating the project. The correct toolsuite for an assembler project is "Microchip MPASM toolsuite"
  5. ect_09
    May 6, 2012
    180
    Thank you so much.
    you guide in a right a way.
    i have done it..
    DerStrom8 likes this.
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I am very glad to hear of your success! :)
  7. ect_09
    May 6, 2012
    180
    Thank you sir.
    its my pleasure,nice:)
  8. ect_09
    May 6, 2012
    180
    T0CON=0x08;
    TMR0H=0x35;
    TMR0L=0x00;
    i want to discuss them.please help me.
  9. ect_09
    May 6, 2012
    180
    and what is the difference between timer0,timer1,timer2...
  10. t06afre
    May 11, 2009
    5,939
    1,222
    Have you read the datasheet? You can find relevant information here. In this case your question is to wide to answer. Be more specific:confused:
  11. ect_09
    May 6, 2012
    180
    >how to set the value of TMR0H and TMR0L;)
    >prescale of timer....
  12. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    It's all in the datasheet. It basically gives you the directions necessary to do it :D
